86 IROC no AC or heat but air blows
Old Jul 24, 2023 | 01:47 PM
David Fite's Avatar
Car: 1986 IROC-Z
Just got an 86 IROC and I can get air to blow out the vents, but I get no cold air or hot air. It's just room temp air no matter what. Any ideas?
Old Jul 24, 2023 | 02:09 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: 86 IROC no AC or heat but air blows
Let's start with the basics. For the AC, does the clutch engage?
Old Jul 24, 2023 | 06:55 PM
David Fite's Avatar
Car: 1986 IROC-Z
Nope it does not
Old Jul 25, 2023 | 10:19 AM
ACebell's Avatar
Transmission: TH350
Axle/Gears: 323
LOL, well that would be a problem with no AC in the car. As a TEST, unplug the cycling switch (found on the dryer) and jump the two wires (with the car running and the AC controls set to ON). If the compressor kicks on then we have low refrigerant. We will need to find the reason why it is low (leaks, etc.)
Old Jul 25, 2023 | 07:03 PM
erik69&85's Avatar
AC is one thing.... But no heat??? That's odd.... Either the heater core is not piped up... Or the bypass valve is stuck... Or the heater blend door doesn't work....
Personally... I would start with the heat... It easier and could point to other issues... Like is their hot coolant going to the heater core.
Old Jul 26, 2023 | 11:25 AM
David Fite's Avatar
Car: 1986 IROC-Z
Thanks for the replies... life got in the way so it'll be a few days before I get to test the things you guys mentioned.
Chevy86 IROC-Z
Jun 21, 2011 04:33 PM
goalieforlife
Jan 1, 2010 06:24 PM
goalieforlife
Nov 18, 2009 12:28 PM
sikZ28
Jan 18, 2009 05:29 PM
