3.1 v6 fan control info
Old Sep 5, 2023 | 08:03 PM
nomadicdogg's Avatar
I've searched threads and google and not getting very far.
My car has a 180 degree thermostat and will run there all day while driving but will shoot up to 220 in town. The fan does not kick on until 220.
Id like to change that. Everything I see is for a 305. Any easy factory style wiring way to get it to come on earlier or am I stuck to doing a toggle switch to turn it on as needed. "I am ok with this but would be happier with an automatic factory style set up.
Any info would be great.
Old Sep 5, 2023 | 08:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 3.1 v6 fan control info
You can lower in the $88 mask , AZTY is 107.8c on primary fan
are you going to 1227730 3.1l to 5.0 L ?
Old Sep 5, 2023 | 08:21 PM
Well the first part of that is well above my pay grade. Laymen terms please.
It has the 3.1L now. I have a 350 in the garage and access to a 5.3. Not sure which way I am going but for now I want to have it run cooler in town.
Old Sep 5, 2023 | 08:24 PM
Engine: Lb9
Transmission: M20
Simplified you can use the ecm to control the fan and set desired fan on/offs in the tune .
Old Sep 5, 2023 | 08:28 PM
completely stock 3.1 But a tuner can change the temp range? Now I need to find a tuner
Old Sep 5, 2023 | 08:33 PM
Engine: Lb9
Transmission: M20
Yes , stock 224 on can be changed in tuner cat or tuner pro rt and just reburn your prom. There’s a piggyback that can be used or solder in a more friendly tunable flash chip like a sst27sf512 eeprom.
https://www.ebay.com/itm/11570397684...mis&media=COPY
Old Sep 8, 2023 | 06:40 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
3.1 is ECM controlled vs the 2.8 which uses a fan switch in the head. You could always bypass the ECM activation and use a manula fan switch in the head or somewhere.
micktroup
Jun 19, 2007 06:38 AM
Gramps
Dec 12, 2006 10:27 PM
Dale
Jul 31, 2002 01:18 PM
Ryan_Alswede
May 15, 2001 10:19 PM
