Heater box delete
Old Nov 8, 2023 | 12:20 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Heater box delete
Guys with race cars or southern cars, who have deleted their heater box, have you done anything to retain some defrost functionality?
At the very beginning and very end of the season, sometimes we do have a need for windshield defrost or defrog. due to how I'm running the downpipe on my turbo, I can't really have the heater box.
I'm tryin to decide if I want to try and run a blower under the dash to go through the heater core, or just buy an inline blower/heater combo (like what is used in marine applications) and duct it to the windshield.
Old Nov 8, 2023 | 01:55 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Heater box delete
https://www.vintageair.com/surefit/c...9&model=Camaro
The newish Vintage Air kit stuffs everything into an under dash unit. Not cheap and you're pulling the entire dash out but full HVAC with a delete plate in the bay is pretty slick.
Old Nov 8, 2023 | 02:01 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Those are cool, especially on the Corvettes.
​​​​​​Ideally, I'd like to avoid having to run the heater hoses from the LS water pump.
Old Nov 9, 2023 | 06:46 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
I'd be interested in finding one too. I have no room under the hood and considered this all in one unit from Summit https://www.summitracing.com/parts/sum-991108 but you still have to run hoses. Ideally an all electric, under the dash one would be nice, for early or end of season nights or when I get caught in the rain.
Brian
Old Nov 9, 2023 | 10:16 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Brian
They make some 12 volt heaters with a 4" tube nipple. I'm thinking if most of the hvac stuff is removed it could be used, BUT directing it to the defrost vents might be tricky. I wonder if it would be better to somehow get it into the factory box.
https://www.boatandrvaccessories.com...0aAmyhEALw_wcB
They also make ceramic heating elements that could replace the heater core:
Amazon Amazon
This unit is 110v so you would need an inverter. A 2000 watt would probably work just fine as the heater is rated for 1500w.
But there is the question of how hot it would get vs a heater core. Heater core probably 240f max. This thing might get double that and melt the plastic.
-- Joe
Old Nov 9, 2023 | 11:33 AM
brian p's Avatar
Car: 86 IROC
the boat/rv one looks like the winner. Found it here as well with dimensions https://www.hebronrvparts.com/produc...watts-8016-btu but the 40 amps tho??
Old Nov 9, 2023 | 03:36 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
480 watts / 12 volts = 40 amps. Question is is 480 watts enough BTU for windshield defrost.
So that's 1,636 BTU.
I wonder if there is data on the btu requirements for this. hmm
-- Joe
Old Nov 9, 2023 | 03:45 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
I live in Michigan, so we obviously get cold. I do not have any HVAC at all. I have never had any fogging/frost issues, even when driving in the rain, when super humid, etc. Just crack the windows and you're good to go. Park inside to avoid frost.
The only reason I have not looked into a heating solution(even though it would make the lady happy) is that they simply draw too many amps for my already maxed out alternator.
Old Nov 9, 2023 | 08:08 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yeah, brother! That's getting bookmarked for later.
Old Nov 10, 2023 | 10:20 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'd be interested to see photos of the actual unit. It says "For cars with factory AC". Concerns me that it might require something in the engine bay. But still cool.
I may do vintage air eventually on my C4.
Old Nov 10, 2023 | 10:43 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I get window fogging a lot here in NH in early spring and mid fall. Typically I only run the sports cars in the summer, but the race car would be early april until late october.
-- Joe
Old Nov 10, 2023 | 10:55 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Read the installation instructions on the Vintage Air website....
Old Nov 10, 2023 | 11:08 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I will when I have a chance.
I wonder if they would sell a heat only kit?
Old Nov 10, 2023 | 11:27 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You need the factory A/C because you adapt the ducting in the dash I think. If you're in for an enthralling hour of excitement, you can watch some dudes install the whole thing:
Old Nov 10, 2023 | 12:43 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oh my gosh, dude... look at the website!
Old Nov 10, 2023 | 12:47 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I did. they don't. They don't sell just the heater box / core / blower.
Old Nov 10, 2023 | 01:23 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
De-feature the AC kit it to meet your wants.
Old Nov 10, 2023 | 10:13 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I get that I can buy the evaporator only kit and then remove the evaporator, I just wish I could buy just the box / blower / heater core.
You'd think a smaller box would be available too as I wouldn't need the evaporator, but I also realize that air conditioning is their thing. Most people probably are ok with their OEM heat.
-- Joe
Old Nov 22, 2023 | 01:15 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
https://www.youtube.com/watch?v=Y6E4LIJsnG0
Got around to watching the video. It doesn't appear to use any of the OEM ducting or AC components, just the vent holes. I do like the defrost vent it comes with with the dual 3" hoses.
I took my heater core out earlier, I think I'm going to remove the rest of the factory ducting. I wonder if vintage air would sell me just a few components. I'll reach out to them and ask. I have no need for the AC, Controls, or floor/dash ducts. Just looking for window defrost.
I'm still learning towards an electric heater element, but if the hoses were run under my turbo and over the inner wheel well (sort of how VA runs theirs) I guess it wouldn't be too terrible.
This is a good option too: https://www.summitracing.com/parts/sum-991102-1
-- Joe
Old Nov 28, 2023 | 12:29 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Spoke to vintage air. They seem pretty good about buying individual parts.
For my purposes, I'm going with the third gen dash defrost (windshield) ducts. Driver-Side Defrost Hose Adapter 592948 $18.00
Passenger-Side Defrost Hose Adapter 592947 $18.00
Defrost Bracket 649649 $38.00
Then I'm using the Gen II heater, 506101 $304.99
This will work well for me. The heater controls will allow me to run windshield defrost and or heater vents, which I prefer to run at the floor . Toasty toes and a defrosted windshield will do the trick.
The gen II heater also comes with an electronic controlled heater valve which goes inline with the hose, so hot coolant wont run through the core when you are not calling for heat.
-- Joe
91ls1t56
Aug 29, 2008 05:54 AM
cobrakiller1989
Nov 4, 2004 01:56 AM
rocky383
Sep 7, 2002 09:23 PM
