A/C Vacuum Tank
Old Jul 1, 2002 | 10:13 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
A/C Vacuum Tank
Today's Canada Day so I celebrated it by working on my car. I'm adding A/C to my car. It got up to 100 F this week. So I pulled out the remaining parts from my heater system and prepped all my A/C parts from a junked car for installation.
My Helm's manual is very thourough on the wiring and part installation, but I can't find out where the vacuum source is for the system. The vacuum tank mounted on the top of the firewall just left of the windshield wiper motor (I think) gets a vacuum from the engine somewhere. Can somebody tell me where it's supposed to be from?
I have a 305 with a 4bbl carburator. Anybody else have this engine with A/C and can trace the vacuum line to the engine for me? Thanks!
Old Jul 1, 2002 | 10:20 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, that sounds like the power brake unit. Are you looking for a vacuum source to operate the A/C controls ??
Auggie
Old Jul 1, 2002 | 10:54 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Yeah, I'm looking for a vacuum source for the A/C. All early thirdgen A/C cars had a vacuum tank with a check valve mounted on the firewall to supply a vacuum. It has two lines, one runs to the A/C controls through the firewall, the other gets vacuum from the carb or the manifold or somewhere else.
The vacuum source is what I need to know.
Old Jul 2, 2002 | 10:18 PM
Auggie's Avatar
Well, I have a 1984 Z28 and I went out and looked for that vac. tank and I don't have one. I looked in my Ser. Man. and it does show a vac. tank mounted right next to the vac. brake booster like you said. I bought my Z new so it didn't have a tank. The Ser. Man. seems to say that the tank was for 6 & 4 cyl eng's ??? The vac. source for my A/C & heater controls is located behind the carb. There is a silver 90* elbow screwed right into the int. manifold runner. I hope this helps some.
Auggie
Old Jul 3, 2002 | 01:02 AM
1986redbird's Avatar
I have your same set-up and my tank is right where you said it is, the vacuum source is routed to a fitting in the mainfold between the carb and the dist. it looks like a elbow with about a 3/8" fitting that screws into the manifold and about a 1/8" barbed fitting the the vacuum hose hooks to.
Old Dec 20, 2023 | 02:21 PM
wilmil's Avatar
Car: 83 Pontiac Trans AM
Engine: 305 CFI
Re: A/C Vacuum Tank
Would it be the same for '83 CFI?
Will
Old Dec 21, 2023 | 10:43 AM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: A/C Vacuum Tank
Old thread response. But I will answer in case someone else is looking for the info. Yes, the '83 CFI had the same vacuum tank mounted on the firewall. Vacuum was sourced from the intake manifold, almost the same location as the carb models.
Old Dec 21, 2023 | 11:34 AM
wilmil's Avatar
Engine: 305 CFI
Re: A/C Vacuum Tank
You have adrawing of the routing to the hvac system? Colors of hoses, etc?
I'll take a picture drawn out on a piece of paper. I just need how to route it.
Thanks,
Will
Old Dec 21, 2023 | 03:43 PM
ACebell's Avatar
Transmission: TH350
Axle/Gears: 323
Re: A/C Vacuum Tank
Not much in the factory service manual or parts manual.
Vaccuum Source Hose (#10) goes to the vacuum port (bottom) pictured above.
Old Dec 26, 2023 | 05:25 PM
wilmil's Avatar
Engine: 305 CFI
Re: A/C Vacuum Tank
Thank you, it's a good start. Which book is this?
Will
Old Dec 27, 2023 | 09:45 AM
ACebell's Avatar
Transmission: TH350
Axle/Gears: 323
Re: A/C Vacuum Tank
I purchased a Factory Shop Manual (not Haynes or Chilton's) from a vendor on eBay. That is where the picture above originated.
gta892000
Aug 11, 2019 11:16 AM
Bohemian
Aug 15, 2017 05:11 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
Strick1
Sep 6, 2015 10:38 AM
