Boiling in over flow tank
Old Jan 13, 2024 | 09:39 PM
JoshO's Avatar
1987 iroc z 5.7 car 20k original miles .. pulled motor cam lifters push rods , seals, springs , valve job timing Chain etc . All new gaskets .. removed the smog pump and emissions .. Car starts runs sounds great .. valve seals needed changed and a lifter had a small tick .. Car never over heated before .. it builds pressure and over heats fast .. changed thermostat twice .. changed water pump twice .. Radiator was checked by a radiator shop said it’s perfect .. new radiator cap..Any advice is greatly appreciated .. I’m out of ideas ..
Old Jan 13, 2024 | 10:08 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: Boiling in over flow tank
Heater core clogged?
Old Jan 14, 2024 | 07:13 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
What do you mean "boiling in overflow tank"? As the engine is warming up do you see a bubble every few seconds? Or do you mean after it warms up you see bubbles? Either way you have air in the coolant system that needs to be burped out.
Do you have the correct rotation water pump?
Old Jan 15, 2024 | 09:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
BBCSwap - U are correct.
xxiamdrewxx
Feb 9, 2009 09:16 AM
berlincam86
May 27, 2006 08:17 PM
BigWhiteGTP
Nov 13, 2005 05:20 PM
KiLLJ0Y
Southern California Area
Mar 11, 2003 04:18 PM
crazygearhead
Jan 9, 2001 03:36 PM
