SoCal guys help me!!!
Guest
Posts: n/a
2 problems..
1# im overheating like a mother, while driving. cools down while sitting idle... hu???? crazy.. things ive done to combat the problem: changed water pump, changed thermo to 180*, replaced my catalytic converter, using premixed 50/50 water mixture, 1 bottle water wetter, replaced upper radiator hose, replaced radiator, replaced radiator cap to 16lbs. my fan runs full time.
WHAT IS WRONG???
#2 problem.
when i start the car, it idles at 1000.. then drops down after 2min to 800rpm... but then i hear a clicking noise in the engine bay.. then the rpms get picked up to 1100... it drops down again.. but then as soo as it hits 850rpms.. it does it again..
what is wrong with this friggin car??? ive been working on these all weekend.. and im tired and pissed..
92 RS LO3 5 speed
WHAT IS WRONG???
#2 problem.
92 RS LO3 5 speed
Axle/Gears: 3.45, 3.27, 3.27
A few things to check.
1) Make sure the air deflector directly under the bottom radiator suppport is in place and in good shape. Our cars are mainly bottom-feeders and require this air deflector.
2) Make sure that the electric fan is sucking air through the radiator and not blowing it forward. It could have the wiring reversed.
3) Check that there is no debris, leaves, shopping bags, etc. in the space between the a/c condensor and the radiator. It is something to check whenever you do an oil change. It is common for a debris to get sucked up into this area.
4) Have the radiator inspected. If it has bad mineral deposits (common if you don't use distilled water or if the radiator fluid hasn't been changed regularly). If it has plastic end caps, I'd suggest replacing it with either a new stock one or aftermarket.
Lon
Lon
Guest
Posts: n/a
ok in that case... i replaced the fuel filter.. and i found a hose comming from the intake manifold, near the distributer, in really bad shape.. i changed the hose.. and that problem went away.
but i will replace the fuel pump later on..
anyone have any suggestions on what brand? i should let you know that one day i will beef up from a 305 to a 350.. still keeping the TBI though.
dave
dave
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
So you have an electric fan? I don't know if this applies to you, but when my car was overheating I replaced my fanclutch to a severe duty one and it made a lot of difference. You may also want to check your heater core. I've had mine re-routed and bypassed and I haven't had a heating problem since
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
dave
what hose was that? and that fixed the up-down idle?
cuz mine does that too...
only when i start it up tho after i drive its fine.
Guest
Posts: n/a
if you have a TBI... if you look at the very back of the intake manifold, right in front of the distributer.. there is a metal tub sticking up with a 90* bend on it.. there is a rubber tube comming off that, then goes into a T junction. it gets hot there and mine was like a wet gummie bear when i touched it.. check that.. its a vacumm line.
#2 problem.
Sounds normal if the car is cool/cold
Sounds like the A/C compressor cycling on/off.
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Originally posted by dunerida82
Your fuel pump is goin out on you dude. Drop the tank, and get a new one. Do the fuel filter of course first.
It sounds like he got his idle fixed by replacing a bad vacuum line. A high or surging idle tends to indicate a vacuum leak/problem.
