1987 Camaro overheating problem
Old Oct 22, 2024 | 08:12 PM
cs2000's Avatar
I have a '87 Camaro convertible 305 LG4/ Auto, last spring we were in a traffic jam and the car overheated, coolant was pouring out of the heater core, so I bypassed the heater core, as money was a little tight this year, the local shop wanted $500 plus, to put a new heater core in it so that's going to be a next year project. so last weekend I had the car out to clean it and get it ready for storage, as I was about to put it away, the temp light came on and it started to overheat. I noticed the fan wasn't kicking on, so after it cooled down, I put the A/C on and the fan kicked on right away. My thoery is back when the heater core blew, it probably got hot and blew the core out because the fan wouldn't kick on. so i'm thinking it could be the fan switch. from what i read the switch is on the left side head. I called my friend at the Chevy dealer and he said the illustration in the parts book wasn't clear where it was located , but the part is discontinued from GM, but there are some dealers that still have it and I prefer to keep my cars with oem parts. Does this sound like it could be the problem, has anyone had this problem before? thanks
Old Mar 25, 2025 | 04:50 PM
ESP1138's Avatar
Car: 1992 Pontiac Firebird Trans Am
Engine: V8 TPI 350 c.i.d. (5.7L), 240 hp
Transmission: automatic
Axle/Gears: RWD 7.75" axle 2:77, 3.27 gears
Re: 1987 Camaro overheating problem
It seems that you are diagnosing your own problem. I wish I could help.
I am having an overheating issue with my '92 TA.
Old Mar 25, 2025 | 05:54 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Disconnect the wire from the switch and ground it. If the fan turns on, then replace the switch. If it doesn’t, then work your way up the circuit (relay, fuse, wiring, etc)
smgseanmicheal
Feb 3, 2013 05:45 PM
CamaroIROC88350
Jul 14, 2010 01:48 PM
David Trimble
Jan 16, 2007 05:05 PM
91blue_fire
Feb 15, 2005 05:32 PM
batmanta01
Dec 29, 2001 11:02 AM
