R134a retrofit
Old Mar 27, 2025 | 04:53 PM
myzticc66's Avatar
Car: 1987 Chevy Iroc Z
Transmission: 700 R4
R134a retrofit
Hi, just going to do a R134a retrofit. I have a new accumulator all the gaskets and connections and a R134a oriffice valve. I also bought a new compressor its a GM 15-20206 replacing a R4 heavy. Much to my surprise the new compressor has no pressure cut off valve on it like the R4. Unless I overlooked something under a snap ring but I dont think so. My question is should I put a cut off valve inline into the discharge line from the compressor to the condensor or just get a compressor with the proper cut off electrical plug. Just got the compressor 2 days ago and it has a 30 day return. Every site I checked says confirmed fit for the 87 Camaro?
Old Mar 27, 2025 | 08:34 PM
myzticc66's Avatar
Re: R134a retrofit
I found an actual R4 at a good price so Im returning the other one.
Old Jun 18, 2025 | 01:43 AM
myzticc66's Avatar
Re: R134a retrofit
So all these new compressors are machined differently hence the new junk o rings that leak. GM does sell a kit that I hear works good
ACDelco GM Original Equipment 15-20058 (02724887) Air Conditioning Manifold Seal Kit with Compressor and Condenser Seals
Old Jun 18, 2025 | 01:20 PM
myzticc66's Avatar
Re: R134a retrofit
Heres the issue
skiroulertx447
Mar 27, 2025 08:36 PM
cbossarte
Sep 26, 2023 08:16 AM
mb2hurley
Jul 15, 2014 06:48 AM
Louis_84
Jul 25, 2010 01:09 AM
Fire"Dutch"Bird
Aug 6, 2008 12:47 PM
