broken fan switch on 91 305 tbi
Old May 24, 2025 | 08:33 AM
Juujaajoo's Avatar
Hi!
I accidentally broke my fan switch while changing headers. Is it possible to just connect the fan switch wire into a manual on/off switch and ground the other end?
Old May 24, 2025 | 08:48 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: broken fan switch on 91 305 tbi
That can be done-just rememer to turn the fan on as needed Never bought one,but i recon a new fan switch is under $40-you can get one with a lower than stock turn on temp.
Old May 30, 2025 | 07:51 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I second just getting a new fan switch,... one day you're not goanna notice the gauge getting hot or forget to turn the fan on and voomphhhh,....... there goes the motor!
Old May 30, 2025 | 08:28 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Yeah, get a new switch...
Old May 31, 2025 | 12:37 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The "broken" switch probably still works, if it's just the plastics that are broken. So if the pin in the connector will still slide into the hole in the switch, then it's likely to stay connected and work.
You can also tap the wire to a ground switch, just in case.
dmccain
Jun 11, 2021 10:57 PM
Stevolwevol
Jul 20, 2011 01:12 PM
big tex
Jan 26, 2001 10:15 AM
