Need help identifying the PROM please help
Old Apr 25, 2002 | 08:38 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Hey all; I have a 1988 Camaro SC with a 1986 IROC Z engine,
vin F LB9 TPI 305. It's been running rich lately and I've been going through certain diagnostics and fixes and none seem to be working. So I figured I'd move onto the ECM and PROM next.
If you were to analyze my receipts for work done to the car by the previous owner, you will see that the ECM and engine were bought at the same engine place, but on different days. This makes me suspect that PERHAPS the previous owner who dropped the LB9 into my car may have been sold the wrong ECM and/or PROM. It could be possible he was given an ECM and PROM for a 350, which would explain why so much fuel is getting dumped into my engine, because a 305 is set up for 19 lbs/hour, and a 350 injects at 22lbs/hour.
So I need help in identifying my ECM and PROM to determine what they were set up for. Is there any codes I could use to see if they're from a 350 perhaps, or for the wrong engine?
Any help is appreciated on this one folks.
Kev
Old May 7, 2002 | 04:26 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
You can call Fuel Injected Systems (210) 654-0774 out of San Antonio Texas and they will tell you all you have to know. They helped me a lot with that too.
David
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
