WINALDL HELP FOR buick turbo
Old Apr 27, 2002 | 10:28 PM
paulrv6's Avatar
I was told by another member that he thought someone on this board had made the cable and used in in their Turbo Buick. I made a cable but it will not read any data.
If someone could point me in the proper direction I would appreciate it. Already posted on the Buick board but not much luck there. Thanks for any help.
paul
Old Apr 29, 2002 | 09:57 AM
paulrv6's Avatar
ttt , co'mon folks, any help on this? May not be the correct place but thought I would ask.
paul
Old Apr 29, 2002 | 12:00 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Did you try it with a 10k R3 resistor?
What engine type and what year is it?
Old Apr 29, 2002 | 12:10 PM
paulrv6's Avatar
Well, I built the cable using 10K resistors (2). I also tried a 10K from ALDL term A to B but it only caused the fan to start and no data.
It is on a 1986 Buick 3.8L turbo GN.
PAUL
Old Apr 29, 2002 | 01:08 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
I think that it should work without R3.
Your laptop may have a weak 12V source on pin 4. You can try an use 12V from the cigarette lighter instead.
/ Jonas
Old Apr 29, 2002 | 02:52 PM
paulrv6's Avatar
Jonas, yea maybe that is the problem because I only get 9.3v out of pin 4 from the laptop. I will try a 12v source from lighter. Thanks
paul
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Nick McCardle
Sep 10, 2015 08:36 PM
