Alternative to a distributor for Accel DFI
Old Jun 2, 2002 | 04:55 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
What alternatives are there to a distributor type ignition when using an Accel DFI (7.0 maybe) setup? I'm not going to have room on my intake manifold for a regular sized distributor, and rather than buy a mini sized distrib for $300, I was thinking for the same price there might be a coil pack / cam sensor setup to look around for? Any ideas?
Old Jun 3, 2002 | 07:49 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
From the DFI Gen 7.0 online help,
Here is a partial list of ignition setups that the DFI Gen 7 is known to work with.
GM (HEI), High Energy Ignition
Universal (IPU), Inductive Pickup
Universal (IPU) with cam sync signal
Universal (HE), Hall Effect
Universal Hall Effect with cam sync
GM (LT1) with opti-spark
Ford (TFI), Thick Film Ignition
Honda VTEC, (IPU distributor)
Buick GN V6,DIS, coil packs
Universal Crank Trigger (includes Flying Magnet, Flying Lug)
Universal Hall Effect Crank Trigger
EDIS Compatible
Dual Sync DFI Distributor (Hall Effect)
Hope this helps.
Steve
Giocio
Oct 1, 2015 12:20 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
Damon
Sep 26, 2015 04:29 PM
