looking into getting ACCEL DFI 7 for my 89 GTA
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
Hi i'm looking into putting the DFI system on my 89 GTA... Currently building a 383 stroker Eagle 383 Crank,,, havent decided on pistons yet but looking at SRP flatops 11.0:1 compression w/64cc head.... iron eagle heads 200cc intake runners .202 .160 valves ,,,,also instead of running the ACCEL ram i will be running a HOLLEY STEALTH ram ANY AND ALL INFO ON THE ACCEL DFI SYSTEM WILL BE GREATLY APPRECIATED THANKs guys
Car: 89 GTA
O.......K.................................... I know someone can tell me plenty on the accel dfi system. WILL someone feed me some info????????????????????????????
www.rancefi.com
www.force-efi.com (I ordered mine from them)
One thing I found interesting is that the Gen 7 does not come with the knock sensor harness, it is an additional 220 bucks. If you plan to run in sequential injection mode you need to get an Accel Dual Sync distributor which provided the ECM with cam and crank posistion signals.. I hope to start a discussion about this unit once I begin the program it, hopefully somebody will take the time to help because what I have learned is it can be difficult to calibrate your first time out of the box.!
Good Luck
One other thing, running pump gas, 11:1 compression and IRON heads is going to be a pinging ****, you may want to reconsider your compression. Running race gas is not an option unless you get the HIGH DOLLAR unleaded because the lead will mess up the 02 sensor.
I was running 9.8:1 with iron heads and it was a pinging SOB and after several failed attempts at an acceptable fuel/timing curve I gave up swapped on a set of Aluminium heads and ordered the Gen 7.
HTH
HTH
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
