Why No Closed Loop
Old Aug 14, 2002 | 10:38 PM
FJK's Avatar
FJK
Why No Closed Loop
While troubleshooting my son's 92 Camaro V6, I noticed the scan tool constantly indicates the engine is running in open loop. The O2 reading is very constant, not varying as much as I'm use to seeing. The car has this extreme power loss, which I'm being to believe is a restrictive CAT.. still not sure yet. Anyhow, what set of conditions for this application must be met to go into closed loop? BTW MAT temp is only being read by a sensor on the dirty side of the air cleaner. No codes are being set. Help!!
Old Aug 16, 2002 | 02:07 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Why No Closed Loop
No codes make it tough since what ever the problem is isn't TOO bad, or not bad enough to exceed the diagnostic limits.
You need a min coolant temp., min time run, an O2 that generates a cross count, and no other malfunctions.
If the cats dead well then start there. Plugged exhaust will kill any engine. While the converter can melt closed, it can flake apart and plug up the muffler too.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
