DB25 pin ALDL interface cable
Old Sep 28, 2002 | 04:25 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
I have searched and searched on this one, but to no avail. Does anyone know what pin to use on a DB25 pin connector for the +12 volts I need that would usually be coming from pin 4 on a DB9 connector (I tried just running this to a hot wire and I think I've fried something in my serial port ). Also, do I understand correctly that I must use a 10K resistor between ports A and B on the ALDL to recieve data?
Thanks all,
Harry
Old Oct 4, 2002 | 07:51 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You can use a DB25
This is a page with different serial connectors:
http://www.passtimeracing.com/eric/Ref/Serial.htm
DB9 -> DB25
2 -> 3
5 -> 7
4 -> 20
You could connect the resistor to a 12V source on te car. In that case you only connect pin 3 and 7 on the DB25 connector.
Old Oct 11, 2002 | 12:50 PM
1MEAN92RS's Avatar
Engine: LO3
thanks for all the help joby. Hopefully I should have this thing working soon.
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
