accel dfi
Old Jan 18, 2003 | 01:58 AM
j91z28d1's Avatar
accel dfi
I just picked up a accel dfi unit 6.32. Does any one know where I can get a wiring diagram for the N.O.S. hookup I don't think the last user was doing it right. It has 3 wires in the plug for nitrous. he was only using one red wire tied into the wire going to the nitrous solenoids. I think it should be hooked so power goes into the dfi from a dash mounted arming switch then the dfi sends power to a relay to the solenoids or maybe its grounds the relay when all the condition are met in the map.
Thanks for any help you can give.
Old Jan 20, 2003 | 02:57 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
Call the DFI Tech Line: (248) 380-2780. Be persistent, they're pretty busy, but when you get someone, they can probably fax you the diagram.
Old Jan 20, 2003 | 04:28 PM
j91z28d1's Avatar
cool thanks. I'm going to ask them about how to record and graft out the run too
Fanatic1074
Oct 3, 2022 05:57 AM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
