im stupid. . .
Old Jan 28, 2003 | 12:34 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
im stupid. . .
ok, what does DFI mean? I know what ecm is, but i cant figure out DFI. Also, what is prom? Is it programming? I know my brother did something with it, but i dont know what it is and does. thanks for putting up with my stupidity.
Old Jan 28, 2003 | 05:11 PM
377Z's Avatar
Car: 2007 Volvo S60R, 2005 Audi A4
Engine: 300HP 2.5L I5, 200HP 2.0L I4
Transmission: TF-80SC, Getrag 6 speed
Axle/Gears: 3.33:1, 3.54:1
From what I've seen, it stands for digital fuel injection; I could be wrong though.
Old Jan 29, 2003 | 07:26 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
DFI = Digital Fuel Injection
PROM = Programmable Read Only Memory
ECM = Engine Control Module
Consider a PROM to be like the RAM in your computer. It is used to store data. The difference between RAM and PROM is that the PROM will not lose memory once the power is removed, but can only be programmed once. An EPROM is similar, but can be Erased so it can be re-programmed.
Old Feb 1, 2003 | 08:18 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: im stupid. . .
DFI, Digitial Fuel Injection, was the first real co to offer a replacement ecm for the oem ecm. They were bought out years ago by Accel and the name term just stuck as an indicator of a non oem ecm.
Programming is the software the ecm uses to figure out what to do. It's a set of instructions. Within the programming is all the calibration data the ecm uses to figure out what values to use in instruction programming.
KED85
Jul 1, 2022 11:59 PM
Dale
Jul 9, 2003 03:37 PM
BigErns90IrocZ
Theoretical and Street Racing
20
Dec 21, 2002 11:53 AM
TomP
Oct 2, 2002 03:43 PM
Project: 85 2.8 bird
Mar 5, 2002 03:09 AM
