why cant run tpi ecm on tbi
Old Feb 7, 2003 | 09:58 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
why cant this be done it would be nice for data loging and many other things
Old Feb 8, 2003 | 12:19 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
ummmmm the TPI has 6 more injectors to worry about , just get the whole TPI system .
Old Feb 8, 2003 | 02:05 PM
c4boom's Avatar
Engine: l98 and lo5
because a whipple for a tbi can not be used with a tpi
Old Feb 8, 2003 | 03:22 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
A 1227730 / 1227727 MAP TPI might work.
ftp://ftp.diy-efi.org/pub/gmecm/manu...727V8TPI-5.jpg
It only has 2 injector drivers and the injectors are wired 4 in paralell. If the injector driver is of 'peak and hold' type then it might work just fine. The rest of the sensors are the same as with the 1228746.
The 1227165 MAF TPI also has two injector drivers, and they ARE peak and hols. Probably the same drivers are used in the 1227730 / 1227727.
Also according to the diy-efi site the 1227165 ECM is used on a L4 TBI engine.
I think that it would work just fine once you have it tuned.
Old Feb 12, 2003 | 12:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: why cant run tpi ecm on tbi
Yes, you can but it's a PITB.
Tuning a wet manifold from TPI means all the AE stuff is wrong.
The actual injector firing STRATEGY, is different.
The actual injector suggested operating times are different.
I've done it, and I didn't see where all the work was worth the effort.
If you go thru things you'll see the 749 ecm is about your only answer since it has two P+H output injector drivers.
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
marcusaw
Aug 10, 2015 08:13 AM
