Where does the ECM get it's power?
Old Mar 4, 2003 | 08:04 AM
Nasty_Bird_'90's Avatar
L98 swap is complete but I have no power to the ECM. My question is where does the ECM get it's power from? Does it have a constant 12v. feed right from the fuse block or does it tap into a relay somewhere?
Old Mar 5, 2003 | 10:43 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
from my understanding, the inside of the car is fed by the starter wires. I think this because, nothing in my interior works when the starter is disconnected. Then, there is an ECM fuse in the fuse block. May not be much info, but it's something to start by.
Old Mar 14, 2003 | 06:53 AM
Randy M's Avatar
The ECM will need an constant 12VDC supply (unswitched) but be sure it is protected by a small fuse. This will allow the PROM to retain the information it has "learned" about several parameters that are reset each time the ECM power is disconnected for more that 30 seconds or so.
89GTAOz
May 16, 2020 09:31 AM
stalkier
Dec 6, 2015 11:25 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
