accel Gen-6 -6.32vc
Old Mar 23, 2003 | 11:24 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
accel Gen-6 -6.32vc
will this run a l98 tpi motor and what problems will i encounter. will the torque converter still lock up and such what options dose the dfi not support.
Old Mar 27, 2003 | 01:39 AM
FAST LiFE's Avatar
You shouldn't run into any problems if installed corretly. As far as torque conveter lock-up, yes it will still work. About the only thing Accel DFI 6 won't do is the emissions and VATS. Everything else should work just like it did with the factory ECU. Use an adapter harness from www.whiteracing.com . It's pretty plug n play with that setup.
Fanatic1074
Oct 3, 2022 05:57 AM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
