surging idle
Old Apr 13, 2003 | 11:47 AM
ssean92's Avatar
Car: sold
surging idle
i have a 92 camaro rs with the 305 tbi, my question is the car surges at idle, and the idle seems to be low. it idles at 600 or so, surges from 600 to 650. i thought it might be the o2 sencor but that didnt help, the question is will the spark plug wires cause this? thats the only thing that i havent changed on the ignision system. They seemed good, just wondering. I also got a oftermaret chip installed wich it seemed to start it after that. im thinking that the chip is finding the things that were not bad yet and amplifing them. any help would be appriciated. sean
Old Apr 24, 2003 | 04:38 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
throttle shaft bushings, perhaps. base gasket? is there a factory ac delco pcv valve rammed in that valve cover grommet? theres a start on the simple items that getcha. base timing also.
Old Apr 24, 2003 | 07:55 PM
ssean92's Avatar
Car: sold
the pcv has ben changed, but will ck the rest taht you said, thanks alot sean
junior419
Apr 7, 2025 11:35 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
