IAC effect running idle?
Old May 15, 2003 | 01:21 PM
87IROC350HO's Avatar
If i adjust the IAC to a running idle of say 700 will it idle higher than usual upon initial start up?
Stan
Old May 16, 2003 | 09:25 AM
Hmmm; Where'd dem Guru's go?
Old May 18, 2003 | 07:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You can’t adjust the IAC without programming a custom chip. You can reset it but it will just relearn again.
Old May 18, 2003 | 10:48 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
i never heard of reprograming nothing... I adjust my iac everytime i do my timing... My car has idles in park at 700 rpms for a very long time unless i read your post wronginitial start up when cold depending on your car will probably a little car but at running temp it will be what you set it at
Old May 19, 2003 | 01:18 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Oh you’re talking about the throttle blade adjustment. Not IAC valve.
If you want to increase your idle speed you can manually override the IAC valve by adjusting the throttle blades “bump stop” screw but you must reset the TPS also after you do this. If you want to lower the idle speed and below what it is idling with adjusting the throttle blades fully closed you will have to edit the settings in the chip.
Old May 20, 2003 | 03:23 PM
I adjusted the "throttle blades as described in the tech article as mentioned above. Now initial or start up idle is just below 1500 then settles down to around 550-600. I'd like to have it idling at 650 all the time but really don't like the high start up idle.
Stan
Old May 22, 2003 | 05:42 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
THe high initial idle is so the engine can warm up some when cold. It should be high on cold starts. On warm starts the engine may rev up to about 1500 but should settle down right away...
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
BurlyChev
Aug 16, 2015 09:08 PM
perZ
Aug 15, 2015 01:17 PM
