DFI 5 tuning question
Old Jun 5, 2003 | 08:11 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I am about to start my motor for the first time after the rebuild. I have a DFI 5 that controls my motor.
My old motor was a 406, 10:1 decent heads and SLP headers into a 3in cat, 36 lb SVO injectors and a miniram and solid roller cam 242/250 @0.050 with 0.657/0.600 lift on a 114.
The new motor is still a 406, 11.5:1, AFR 210's and Hooker Super Comps, same 36lb injectors with a miniram with a new solid roller with 248/248 @ 0.050 with 0.615/0.615 on a 110
The question is, do you think the old program is close enough to start the new motor without hurting anything considering the exhaust flows a lot better, heads flow better and cam changed?
The motor ran good with the old setup and was tuned at Cartek in NJ. I just want to know if I can start the car and run for a little while without going back to shop to tune it immediately.
Steve
Old Jun 6, 2003 | 12:35 AM
FAST LiFE's Avatar
Your old motor's setup is not too far off from the new motor so You should be fine with your old motor's fuel and timing maps. Of course you will have to fine tune your fuel and timing maps to get the most out of your new setup.
Old Jun 6, 2003 | 05:48 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Ditto,
at the lower loads the difference in flow while different still is 1/2 way close. Just work your way up in building your tune. ie idle first then light cruise, the 1/2 load, then WOT.
MustangBeater20
Oct 29, 2022 09:20 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
marcusaw
Aug 10, 2015 08:13 AM
