How much to pay for a 7749?
Old Jun 18, 2003 | 03:37 PM
Zac's92's Avatar
What have you guys paid in the past for this ecm? was it original or remanufactured? Anyone have one for sale?
Thanks,
Zac Spalding
Old Jun 19, 2003 | 07:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: How much to pay for a 7749?
Shopping around at junkyards or on the net should turn one up for under $75. 50 being usual.
Old Jun 20, 2003 | 01:27 AM
CrazyHawaiian's Avatar
Car: too many ...
Maybe I got screwed but I paid $100 for mine (used) out of a 1992 Syclone. Add $25 for shipping to Hawaii and the total was $125. There are so few Sy/Ty's here on island it would be pretty much impossible to find one at a yard. I found this 749 ECM on the Sy/Ty web forums for sale section (some guy parting out a wrecked 92 Sy).
Old Jun 25, 2003 | 04:49 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
I picked mine up from a wrecking yard for $50. I pulled it from a 1988 Grand Am with a quad 4 if I remember right.
Old Jun 26, 2003 | 10:42 AM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Didn't SATURN5 use a 7730 in place of a 7749 and it worked fine? I believe that he did and that you don't need a 7749 ECM.
Old Jun 27, 2003 | 03:46 AM
Car: too many ...
Yeah you can convert a 730 ECM to a 749 ECM. It requires you repin the 730 to 749 specs and replace the 1 bar map sensor with a 2 bar map sensor. The only advantage of the 749 over the converted 730 is the 749 has an extra injector controller and driver. This means the 749 can run low Z (P/H) TPI injectors but the converted 730 ECM running $58 code requires you use high Z (saturated) TPI injectors. Although you might be able to run low Z (P/H) injectors on a modified 730 if you mess with LJ's impedence converter.
ZEEYAA
Apr 16, 2023 08:29 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ronscott80
Interior Parts Wanted
Oct 13, 2015 12:26 AM
Royal_Z
Sep 30, 2015 08:45 PM
