WinALDL 160 baud no good with TPI?
Car: Check The Sig
I have the WinALDL software, but i dont know if it will work with the faster rate TPI ecm? It says 160 baud, and i belive TPI operates at a faster 8k baud right? I wana order a cable soon, and I need to know about the software, and also what do i need in my lap top to run winaldl?
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The Winaldl is 160 baud but I think it works with the 8k baud ecm. I use Winaldl on my car but I have the POS '870 ecm which is 160 baud. The '85 is TPI but still has the 160 baud. Just my luck. Anyway, another program you could use is the Moates software. I think his would be better I just wished it worked with the 160 baud. The cables are different for the 2 programs I think. The Winaldl cable only uses one transistor. I made one for about $4.
Sanjay
Aug 12, 2015 03:41 PM
