ECM/sensor causing high idle speed?
Old Sep 10, 2003 | 08:17 AM
Rich J's Avatar
I have an 87 GTA, 5.7l auto. The car runs fine except that once I get above around 40mph, and then decelerate, it will idle at 1200 rpm until about 3 seconds after I come to a complete stop. If I put it in neutral, it will stay at 1200. If I don't get it above about 1200, it will idle back down to 600 or so normally.
I have replaced and reset the IAC and the TPS, switched ecms, and checked the throttle linkage for binding.
The only other thing I can add is that I replaced the trans a while back but I can't remember if this problem started right after that or not.
Is there any sensor or other input that could cause this to happen?
I have a OTC 2000 scanner and could check some of the readings if that might help?
What do you think might be causing this problem?
Old Sep 10, 2003 | 07:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Coolant temperature will cause this if the ECM sees that it is low.
RBob.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bamaboy0323
Sep 3, 2015 06:07 AM
ezobens
Aug 19, 2015 10:29 PM
perZ
Aug 15, 2015 01:17 PM
