closed loop and open loop
Old Sep 16, 2003 | 04:08 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
What exactly causes each of these? I've been looking and I can't find a whole lot.
Lets say I start my car.... 15 minutes later (5 min idle warmup) the following happens:
The RPMS go from 1200 to 700-650 after 2-5 minutes
I drive out of my driveway
The idle goes back to the 1200
At the only stop I encounter, the RPMs can either be at 1200 or 700... depends on what day it is
At my destination, the idle RPMs are at 700
My ALDL logs are showing that it never entered closed loop, and frequently issues a "forced to open loop"
I need to know what conditions would cause it to stay in open loop, and what needs to be at certain specs before closed loop starts
(i'm guessing my EGR valve and my o2 sensor... but i'm not sure)
Old Sep 16, 2003 | 06:33 PM
Zac's92's Avatar
coolant temp sensor getting a low or erratic reading would cause that. check the cst in the front of the manifold. The contacts may be corroded or the sensor may just be bad(mine was cracked).
the ecm has to see above a certain temp from that sensor to go into closed loop, so if the sensor is giving erratic readings it could force it to open loop.
Zac
Old Sep 16, 2003 | 10:00 PM
MechCD's Avatar
Engine: LO3, Vulcan
Ok, the coolant temp hit 180 by the end of the run with no erratic reading, just a smooth curve. The IAT stayed around 70F the whole time
Is there something else that needs to be at a certain value?
I still think my EGR valve isn't working, but I just realized the ECM has almost nothing to do with the EGR valve
Old Sep 20, 2003 | 03:25 PM
MechCD's Avatar
Engine: LO3, Vulcan
Ok, I drove around for 45 mins today and according to WinALDL, I never hit closed loop. The BLMs did their thing. The O2 was varying quite a bit.
The new EGR valve helped out my idle a little bit also.
Do I need to not accelerate or stop for the ECM to enter closed loop? I was on a highway for about 10 mins, but that was all the longer I could go without really going out of my way for a cruise.
As far as i know, it's not throwing any codes
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
luvofjah
Sep 3, 2015 07:08 PM
