1227165 Board pics needed.
Old Oct 17, 2003 | 12:05 AM
GMH_VQ's Avatar
Car: Holden VQ Statesman
Engine: 5.0L V8
Transmission: 5sp Manual, IRS
Hi Guys,
This is my first post. I have spent a large part of last evening reading a whole bunch of posts about the '165 ecm. And have search heavily for pictures on this forum and on the web.
I have one of the 1227808 ecm variants in my Aussie Holden VQ Statesman. A 304CI V8, with late style factory cold air and decent exhaust.
Iam trying to run 32k $12 calibrations (BFPM) instead of ASBX 16k.
From everything I have learned I can run the Knock Sensor enhanced code and also have the benefits of lean cruise, and block learn functions in the old girl! I have bought a new BFPM memcal, and a KS and harness.
One small hassle however, is the use of a Security Code in the later software, that requires a serial data stream into pin A8 @ 8192 baud.....from a body control modual which among otherthings takes care of the car alarm.
I managed to find a company who make a BCM simulator to allow non modified factory memcals with security enabled to work.
But my 808 spec ecm can't communicate at 8162... only 160baud.
I have obtained every component needed to retro fit the U2 SXR uart into my 808 to bring it to 165 spec. Using a bright lamp, and tracing the circuit board, and using the schematic diagrams from Ludis.. I have determined..I think.. where everything goes.
But I need to know for a double check, which points on the board intensionally has nothing fitted.
I would like to know if someone has a good set of scanned pictures of both sides of the 165 computer board. I have a pic of the 'memcal' side, but not the bottom.
Can someone help..
Sean
Thanks for the info learned already, always nice to find another good web source of info.
ctoledo0834
Sep 18, 2015 04:16 PM
87hellbird
Sep 14, 2015 05:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
09ave
Sep 7, 2015 06:03 PM
