Which system?
Old Oct 19, 2003 | 05:17 PM
Crisis's Avatar
Which system?
I got my setup all figured out exept for the ecu part.
The intake system is all figured out. The intake has been disinged and i'm getting 4 tbi units on top of it. Its an I.R (idividual runner) type mannifold and each tbi is feeding opposite 2 cyliders.
I really wan't to build up this setup that we thought up, the only problem is controlling the injectors. Wet manifold types have great potential in n/a systems as long as the runner leagths are "tuned" for the right rpm range. And with 8 x 55ph injectors i really wouldn't run out of fuel. I even might have to considure smaller ones.
Oh yeah.. this is going on top of an 383 with forged internals. And mated with a nice valve train giving the upper end one air
My question specificly is that what ecu would i need to drive the tbi injectors? Would for exaple a haltech system take to load of the big injectors?
Please. Don't flame the idea. Just help with the ecu choise.
Old Oct 20, 2003 | 01:53 AM
CrazyHawaiian's Avatar
Car: too many ...
I would recommend the Holley Commander 950, because they currently have a multi-TBI injection system controlled by the 950. I'm thinking the stock 730 ECM from any Speed Density TPI car would work with a custom chip, but I'm not certain so I wont say it will. I recommend you PM one of our members, Kingalt0n. He has had expeience with the Commander 950 and big power TBI setups. Good luck!
Old Oct 20, 2003 | 08:37 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
55 lb injectors are going to be low impeadance & will need the right drivers in the ECU, that leaves the aftermarket as your only choice. The Holley will do it, but you will have to upgrade the firmware to handle 8 low imp injectors.
Old Oct 20, 2003 | 01:24 PM
Crisis's Avatar
Nice.
Are high impeadance injectors availible for the tbi injector pod?
If the commander 950 will do. can i change the firmware with the laptop? Would holley charge for the firmware swap (if i can do it my self)?
I read half of the posts on this board last night on came to the conclusion that the commander would be the best cossidering my budget/aplication.
What if the injectors were wired in series. would there be enough current to open both injectors?
Old Oct 20, 2003 | 06:05 PM
Zac's92's Avatar
wired in series the current would be the same across both injectors. the voltage is what would drop and your injectors wouldn't open all the way
Old Oct 21, 2003 | 06:59 AM
Crisis's Avatar
and running them in paralell would burn the transistors? right?
What rick mean by fireware... as in firmware like cd-rom drives ect..????
Does the commander need physical changes to run the 8 injectors?? how about the high-resistance injectors?
Old Oct 21, 2003 | 06:06 PM
Zac's92's Avatar
the commander 950 should be able to run eight hi imp. injectors
call holley's tech line they can answer all of your questons
Zac
Old Oct 21, 2003 | 06:24 PM
Crisis's Avatar
Call holley... yeah right. From finland?
(i'll be broke before i even get through. finland is +2 cet)
no offence intended
I read the posts in this topic again and noticed i must have been a little tired writing the reply posts. lol
"The Holley will do it, but you will have to upgrade the firmware to handle 8 low imp injectors."
tbi injector are 12ohs if i remember correctly, is that high or low imp?? I don't know the scale.
Anybody upgraded the firmware? whats that all about? I've heard of upgrading for example dvd-players.. never heard of ecu's having firmware upgrades.
thanks for the replys...
now i have more questions than answers
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
