O2 sensor
Old Nov 1, 2003 | 11:30 PM
stupid4901's Avatar
O2 sensor
i was looking to buy a wideband o2 sensor for my car, and was wondering where i could find one. There are a couple 4-wire ones available on ebay. Would that work?
Old Nov 2, 2003 | 12:01 AM
Jester's Avatar
4 wire sensors aren't wideband....just heated. I forget how many wires a typical wideband has....I wanna say 7 but I could be totally off.
You'll need a matching setup to get any readings from the sensor too...you can't just plug it into your stock ECM or $30 gauge. I'm gonna move this to the DFI and ECM board....you should get more help there.
Old Nov 2, 2003 | 06:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: O2 sensor
Currently there are two decent options available. One is a DIY unit that is a great bang-for-the-buck unit. Infomation can be found at www.diy-wb.org. This is a non-profit unit that has been around for a while.
For a commercial unit the LM1 from Innovative Motorsports is decent:
http://www.innovatemotorsports.com/
The two popular WB sensors are the NTK/NGK and Bosch units. Both are a five wire sensor.
Old Nov 2, 2003 | 03:36 PM
stupid4901's Avatar
Since I have no idea how to make my own even with all that info, I'm leaning towards buying that kit. Will it bolt right up? Is there anything else I need for it?
Old Nov 3, 2003 | 11:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You will need to purchase the sensor separately. IIRC Autozone has them for a decent price.
The output of the diy-wb is a voltage level. This translates to the measured AFR. This output may be data logged by a separate unit, by the ECM with modified code, an LED display or even a DVM.
There is a site that has the ECM code for data logging through the ECM. The AFR is sent out the ALDL port for use by a scan tool or something like Moates scanner/logging software.
RBob.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
