Where to buy new ecm??
Old Nov 16, 2003 | 08:56 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Im sure this question has been on here before but I have no luck on finding it so I am forced to make a thread.
My question is where can I buy a new ecm online. I thought about GMPartsDirect.com but I cant seem to find it. Also is there a certain model I should get. Thanks
1991 Camaro Z28 TPI 350
Old Nov 16, 2003 | 11:53 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
I realize you said new, but could try a salvage yard for a used one. There were alot of V6 cars that had 7730's also. I got mine from a Celibrity for $50.
Old Nov 17, 2003 | 12:33 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Corisica I mean... not celebrity. Berreta's had them also, and I'm sure there were others with that body style with V6.
Old Nov 17, 2003 | 07:44 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Any early 1990s J-body (Cavalier, Sunbird) with a 3.1 and many of the N-bodies (Corsica, Berreta, Grand Ams) with 3.1s had 7730s. There were some late model 1988-89 cars 2.8 FWD cars that also used the 7730, but many also used MAF - so be careful.
Lastly, the W-bodies (Lumina, Grand Prix, Cutlass, Regal) from the early 1990s with 3.1s used the 727 which is the version from the Vette and can be adapted also.
But if you want a 7730, just say you have a 1991 3.1 Cavalier an any wrecking yard will be able to cross-ref the 7730 for you. They tend to pull those and just cross-ref.
Old Nov 17, 2003 | 08:27 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Even the 7730 in the cars with a 2.8 MAF will work, it's in the code that the switch from MAF to MAP, and GM did exactly that on some applications. A 7730 is a 7730 anyway you look at it...(Unless someone has been inside it messing around .....
Old Nov 17, 2003 | 09:57 PM
Car: Death Mobile
Engine: 666 c.i.
I was not clear in my post. YES, the 7730 that used MAF will work. I meant to say, be careful because a lot of the 1980 2.8 MAF cars are not 7730s. Only some of the late 80s versions were 2.8 MAF with 7730. But all the 3.1s (except W-bodies) in the early 90s are definitely 7730s.
And this post should be on the DFI/ECM Board.
Old Nov 18, 2003 | 07:40 AM
JP84Z430HP's Avatar
Car: 84 Z28
Makes sense now that you say it, and I think about it again. I'm pretty sure that the one that were DIS were 7730's and the older ones with a distributor aren't. Guess it's a non-issue though, all you need to do is say that you need a 1227730 service number, and they can get ya one of the shelf! At a parts store, they should be able to put 1227730 into their computer and get ya one....
Old Nov 18, 2003 | 04:03 PM
white91Z28's Avatar
Engine: TPI 350
I looked on thirdgenresource, and it shows that a 1991 5.7 has a code of 16198262 and a 5.0 has a 1227730. So I need the 16198262 right, or am I completely wrong..... heres a link that I saw the info on http://www.thirdgenresource.com/tpi_facts
Old Nov 18, 2003 | 04:45 PM
white91Z28's Avatar
Engine: TPI 350
also what is a memcal? Do I need to change it over from the old one to the new or do I have to buy a new one or what?
Old Nov 18, 2003 | 05:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 16198262 and the 1227730 are the exact same ECM. The 16xx.. is just a newer GM number.
The MEMCAL is a plug in part that has the calibration (EPROM), the knock filter, and the limp home circuit on it. It is easy to swap over the one you currently have. This is the piece that makes the ECM work with 'this' engine.
The price of the ECM should also be based on whether it comes with the proper MEMCAL or not. Less money if not.
RBob.
Old Nov 18, 2003 | 07:01 PM
white91Z28's Avatar
Engine: TPI 350
OK on gmpartsdirect.com I put the 16198262 # in and it says its an "ECM-REMAN" and its usually going for $220 and they are selling it now for $110. Is this right?
Old Nov 23, 2003 | 06:38 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
That is correct the toal price is $220 -$110 core charge when you return the old ecm for a total of $110 + S/H. But you pay the $220 up front.
Old Nov 24, 2003 | 10:47 AM
kpowr82's Avatar
Don't mean to steal this thread or anything, but when you by a new ECM, do you just swap it in? Is there anything else required or do you just plug it in?
thanks
Old Nov 24, 2003 | 11:12 AM
DJP87Z28's Avatar
Just put your old chip in (aka memcal) and plug iit in,
Old Jun 11, 2004 | 11:21 PM
plower's Avatar
Engine: 1988 305 TPI
Where can you purchase new memcals. I have a problem where the fuel pump does not shut off at times after the car has run for awhile and thinks its the memcal. It is a 88 305TPI f code engine. Is this a GM only thing?
Old Jun 12, 2004 | 07:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, MEMCAL's are GM only. As for the fuel pump check both the fuel pump relay and the oil pressure bypass switch. Either could be sticking on.
RBob.
Old Jun 26, 2004 | 10:14 PM
muffz28's Avatar
Car: 1992 Camaro Z28
If I were you I would go to an autozone or another parts house and get a reman one. I know autozone carries A1 Cardone which has a 1 year warranty and it should run you about 75.00. Just so you know A1 is the ramanufacturer of ecu for GM.
Part #77-7730
F.I. 57 Belair
Aug 23, 2021 01:09 AM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
