Can't Get Error Code
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
Hi,
I've recently got myself a 88 GTA it's previous owner had a 75amp alternator installed so I changed with 105amp alternator. My problem is I can't get any error codes from the ecm (Service Engine Soon light is on). I took my car to a service they were not able to connect to ECM either (Using their scanner). They told me prom chip burned probably because of the old alternator. My Car currently starts and runs fine without any problems.
My question is can I have working ECM only by changing the prom chip or Do I need to change the whole ECM unit.
Car: check
Engine: check
Transmission: check
Re: Can't Get Error Code
Originally posted by <<K-O>>
Hi,
Hi,
RBob.
