V6 harness to V8 ECM
Old Dec 25, 2003 | 06:39 PM
dennis6's Avatar
Car: 1991 Camaro RS
is it possible to add the wiring for two injectors, and then cut and splice the wiring at the ECM connectors. Then install a V8 ECM and be done?
Old Dec 25, 2003 | 11:12 PM
11sORbust's Avatar
I think so (if you are talking mpfi)..might be trying it out soon..
Old Dec 26, 2003 | 12:51 AM
dennis6's Avatar
Car: 1991 Camaro RS
Yeah, I was talking about a MPFI to MPFI.
Old Dec 26, 2003 | 03:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: V6 harness to V8 ECM
Converting a V6 harness to a V8 harness is do-able. The cut & splice at the ECM is not recommended. If wires need changing it is common practice to pop the pin from the connector and re-insert it into the proper connector location. Going from the V6 ECM ('7302??) to a '165 or '730 isn't difficult. This is on your '89?
Best is to decide which ECM you are going to and then get wiring diagrams for both. then you'll be able to tell which wires require moving.
RBob.
Old Dec 26, 2003 | 08:01 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks Rbob. Yes, its just brainstorming for my 89.
What about the connectors to the TPS and other sensors, are they the same?
Old Dec 26, 2003 | 08:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
As far as the connectors being the same, I don't know. It can also depend upon which years you are swapping between. This is sorta' one of those things that you need to research/jump-into to find out what is required.
RBob.
Old Dec 26, 2003 | 11:00 PM
11sORbust's Avatar
it looks like it will work. I think my v6 has the same tps and the wires are the same color as tpi...
Old Dec 27, 2003 | 09:36 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks everyone nice to know its possible.
88SS6SPEED
Nov 11, 2015 07:05 AM
2012sergen11
Oct 13, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
efiguy
Sep 27, 2015 01:30 PM
Billy Decker
Sep 4, 2015 03:46 PM
