Anything I should tell the guy?
Old Feb 20, 2004 | 05:37 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im going tomorrow and have a guy make me a custom chip for my car....anything important that I should tell him? I have not run it on any diagnostic software but he did say that when I do he will update it to whatever the data reads..but till then anything I should let him know or anything in paticular that should be done...
He's going to be going off whats in my sig..
thanks!
Old Feb 21, 2004 | 11:56 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
If the guy isn't going to scan your car before he burns you a chip, he's just going to be guessing. You can do that. You'll probably be paying him almost as much as it would cost to get most of equipment you would need to do it yourself. 200$ dollars will get you burnin chips and learning alot about your car. I suggest you read Traxion's chip burning intro, it explaines alot. If you have a laptop you can either build or buy a cable and use either winaldl (easier to use) or Moates' software(much much faster) to scan your car and see what it needs for yourself. Like I said if this guy doesn't hook up to your car and see what it's doing now he's just guessing at what to change in the chip. He will have no idea what your car really needs.
If you decide to get the chip done by this guy, let him know what temp you want your fans on, if you want the torque converter lockup characteristics changed, and if you have vats you can disable it. You have changes alot so a little timing and getting your fuel curves right will take some time. When I say getting your fuel curves right I mean scanning your car while you driveing it to see what it needs. There is no way to guess at that. This will take more than one chip. No questions asked, you can't get it on the first time.
Old Feb 21, 2004 | 03:47 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yeah, tell him to take a hike! Your setup isnt that much farther away from stock. You should just buy the prom burning stuff yourself and be done with it. Not only that but you can always change things in the future if your not satisfied with them.
Old Feb 22, 2004 | 06:57 PM
BMmonteSS's Avatar
Car: 84' Monte
Let us know how it went
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
