tps problem
tps problem
hello i am using tuner pro rt for aldl emulation the tps is showing 1.89 volts eventough when i put a volt meter to the tps it shows .54v i have changed ecm and eprom ?also if i unplug the tps it shows 25volts i tried to adjust and the volts go from 1.8 to 12v?on the aldl?also with the tps hooked up when i push on the throttle the voltage goesw down?the gray wire has 5v the blue i think .54 and the black is ground and i have also grounded it to the throttle body and no change.any ideas?
:hail:
:hail: Moderator
Car: check
Engine: check
Transmission: check
Re: tps problem
:hail:
:hail: RBob.
92camaroJoe
Aug 13, 2015 06:07 AM
