ECM Harness HELP!
Old Mar 9, 2004 | 08:25 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
ECM Harness HELP!
OK, so i took it all out of the car, switching to carb.
Anyone know how to fix the lockup on the tranny and wire up the fuel pump.
And do i need anythign else of the harness.
And what are those 3 other plugs right in the dash with wires going to the ecm and the engine comp.???
Old Mar 10, 2004 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can re-wire the fuel pump relay to the igniton switch. Ignition on, fuel pump on.
As for the TCC there are several methods: rewire for lockup once in 4th (tranny harness), use a vacuum switch to activate, separate controller. Tranny board has some additional info on this.
The ECM harness plugs near the dash are for the VSS, SES, ALDL, Bat+, Ign, stuff like that.
RBob.
Old Mar 11, 2004 | 08:26 PM
Charged350's Avatar
Car: 87 IROC Z28
its a 87 so my speedo is machanical i have found out, but there is 3 connectors, do i need any of em for this swap, or no, cuz the bulkhead connector on the drivers side has all my baterry , starter and **** like that on it...so whats da deal.....
F.I. 57 Belair
Aug 23, 2021 01:09 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Billy Decker
Sep 4, 2015 03:46 PM
