is a new ECM needed?
Old Mar 21, 2004 | 05:21 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
i have an 86- z28.. the car is origionally a 86 lg4 305 carb'd 5 speed manual. i now have a 350 4bolt. bored .040 over = 356....i have an aggresive cam and higher compression and aluminum heads off a 90 vette. differnt exhaust and intake manifold. i do however have the origional carb onb there. it has been rebuilt, but there are still wires running to it. i have the stock distributor with a 50k volt coil, and good accel wires...with platinum plugs. the fans are NOT controled by the computer, and i took the A/c out. i have also taken the air pump for the emssions out; but i do retain the EGR valve, and air/fuel sensor.
although i have cut back on alot of the wires under the hood, would it be benefical to get a custom chip for this motor, or is the origional chip good enough?
all i can see the computer running is the carb, the knock sensor, and the air/fuel sensor...
im really looking for someone to tell me the truth please help.
Old Mar 22, 2004 | 07:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'd suggest the same as Grumpy recommends:
https://www.thirdgen.org/techbb2/sho...&highlight=ZZZ
Seems as though it would be a good match.
RBob.
Old Mar 27, 2004 | 09:12 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
ive done a web search for the installation guide and no luck locating..can anyone give me a link or a point in the right direction?
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 19, 2015 10:02 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
