ecm bad? or not
Old Mar 28, 2004 | 11:32 PM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
ecm bad? or not
just wondering if anybody recognizes these symptoms as a ecm prob. after starting it runs normal for a second at high idle then sputters and dies. if i step on gas it runs like the timing is way off and dies with a backfire thru the throttle. i had the ac hooked up with no diode and i spiked the ecm i believe. the fuel pump checks out as being bad or on the verge of bad but it seems like more that that. has anyone had this prob?
Old Mar 29, 2004 | 07:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ecm bad? or not
I was thinking fuel pump before I even got to that sentance. After a new fuel pump & fuel filter, if the problem persists I would consider/test the igniton module and distributor pickup coil.
RBob.
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
