Cam and ECM question...Newb to ECM's
Old May 27, 2004 | 02:46 PM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
Car is equiped w/ 165 ECM. But I would like to know if the cam I am about to purchase is "MAP sensor friendly" as I am going to either swap to a 730 or Megasquirt. Thanks in advance...Here are the specs I have for cam:
246/254 @.050 duration
.558/.558 INT/EXH Lift w/ 1.5 rockers
and 112 LSA if I recall...it is the cam in summit part number TFS-K314-500-450. Thanks for any help you can provide on what ECM I should use w/ that cam. I just don't know if it will pull a stable enough vaccum at idle for a MAP based ECU. And by that for me to get it to idle w/ a MAP based ECU.
Old May 27, 2004 | 07:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cam and ECM question...Newb to ECM's
For the most part this comes down to how good of a tuner is at the helm. I'd recommend a search on DIY PROM for 87_TA and Traxion. They are/were both running some radical SD/'730 setups. If it were myself doing the tuning I wouldn't worry about it. But I've also be at it for quite some time.
RBob.
mddaniel
Sep 8, 2015 05:16 PM
bamaboy0323
Sep 3, 2015 06:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
