ECM need replacing?????HELP!!!
Old Jun 27, 2004 | 07:26 PM
chuck383rs's Avatar
I have a 1991 Camaro RS with a 383 in it and it has been running fine for years!!! But now I am having a problem with it missing and backfiring. I have put on a new distributor cap, new rotor button, new spark plugs, new spark plug wires, checked my MSD Digital 6 Ignition Box according to MSD (and it is functioning fine) and my car is still missing, popping, backfiring and not running right!!!! My check engine light is not coming on. The car seems to run fine as long as you don't "get on it". Doe this mean I need to replace my ECM??? I have had to have it replaced once in the past but I do not remember the symptoms it was having. Do I need to replace it again???
Old Jun 28, 2004 | 07:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM need replacing?????HELP!!!
My first best guess would be a fuel delivery problem. Check everything mechanical too, battery cables, ground straps, plug wires. . . As far as the ECM try to get/beg/borrow a known good one and try it.
RBob.
Old Jun 28, 2004 | 09:06 AM
chuck383rs's Avatar
Re: Re: ECM need replacing?????HELP!!!
RBob.
Thanks for your reply. I have a fuel pressure gauge in the cockpit and it is reading normal with no variations in pressure. Do you think it could still be a fuel delivery problem???
Old Jun 28, 2004 | 05:24 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
A datalog would possibly show something erratic, maybe O2 took a dump or EST is screwing up.
No easy way to tell without seeing something, although symptoms do sound fuel related.
Old Jun 28, 2004 | 08:36 PM
chuck383rs's Avatar
What is a datalog?
What is an EST?
Old Jun 29, 2004 | 11:07 PM
JP86SS's Avatar
Datalogging: Using a cable and a laptop computer to read the serial output data from the cars computer. Readings can/will be of O2 sensor, throttle position, rpm, Manifold Absolute Pressure, yadda, yadda, yadda.
EST is Electronic Spark Timing and is ECM controlled for advance and retard of the distributor.
Connecting should show you what is working and what is not.
Do some searches and reading in the threads to find out how this is done and the hardware/software requirements.
Once you start, you'll never live without it again!
Also Have you considered the fuel filter?
Check the connections on the fuel pump circuit as well.
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
stalkier
Aug 21, 2015 01:54 AM
marcusaw
Aug 10, 2015 08:13 AM
