ECM Problem?
Old Jun 28, 2004 | 02:04 PM
Indy GTA's Avatar
Car: 2000 Firebird, 1988 GTA
Engine: V-6, V-8
Transmission: 4L60E, 700R4
Axle/Gears: 342,373
ECM Problem?
I have a question about the ECM. Will a bad ECM not be able to throw codes? I have a SES light on but when I try to test it with a Snap-On scanner it tells me that it isn't getting a response and that I have to make sure the ignition is turned on even though it is. When I try the paper clip it won't even flash a code. The fans go on automatically when I turn the key to the accessory. Once I get it started after 20 tries the fans are still on and idles and drives fine but runs extremely rich. I've even tried a new prom chip. It runs worse on the new one than the one installed. It is a factory car. No mods unless you count the K&N filter(I don't). It also has 144,000 miles on it. If anyone has had this problem or can help me out I would greatly appreciate it.
Old Jul 5, 2004 | 01:44 PM
Indy GTA's Avatar
Engine: V-6, V-8
Axle/Gears: 342,373
I've found my answer in the TPI section under the title Error Code 34 MAF, Help In Germany if anyone else has this problem that I have.
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
inferno15
Aug 29, 2015 01:48 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
