160 vs 8192 baud
Old Jun 21, 2004 | 10:17 PM
eddie jr's Avatar
160 vs 8192 baud
ok, been doing a lot of searching trying to learn about connecting to the ALDL and have a few questions:
1. So what is the difference between 160 and 8192 baud?
2. I have seen different diagrams for building ALDL cables. Is one design better than another? How do I know which one I need or should use?
3. Can you actually buy an ALDL plastic connector somewhere to put on the end of your cable so you don't have to plug the individual wires into the ALDL?? (Just plug the connector into your ALDL)
thanks.
Old Jun 22, 2004 | 08:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
1) Speed. The baud rate is the rate of data transfer. 160 baud is VERY slow.
2) The kind of computer in the car will determine what you use.
3) I don't know about that one.
Old Jun 22, 2004 | 05:04 PM
eddie jr's Avatar
So does the slow transfer mean that when reading the info from th port to a laptop that it will not gather data efficiently?? Also, does this mean that the computer actually processes slower (ie. slower to react to changes from sensors etc?)?
I have an 85 2.8. Do you know which one comes in that car??
Old Jun 23, 2004 | 01:42 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The data rate of the ALDL doesnt determine how fast the ecm handles operations, jsut how fast the data is sent out. The 160 baud means that youll be sending a max of 20 bytes per second where as teh newer ecms with different hardware and 8192 baud can send a max of 1024 bytes per second. Big difference in how fast youll get data. Matters alot if your using it for tuning. The faster datarate is really a must from that standpoint if your using an FI system. AFAIK the carb ecms xmit at 160 baud so youll only need a single transister cable like whats shown with winALDL.
Old Jun 23, 2004 | 10:58 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
The 870 ECM for the 85 TPI cars is 160 Baud as well. I have an 89 computer (8192 Baud) and a couple of No Vats chips (one stock, one not). I need to double check the wiring of the adapter harness I have because a guy with a scanner said my 'A/C was showing to be running when it was off. That's why I'm running the 85 computer again. I've fried too many A/C units since I switched to the 89 computer. I really haven't run the custom chip that much so I need to get my software/hardware act together so I can check this stuff for myself......
Old Jun 23, 2004 | 03:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The 160 baud is like looking at a calendar to tell you what time it is. At one update per second, most events have already been there and gone. ie a throttle blip might be entirely missed.
The 2 transistor version work fine.
Old Jun 23, 2004 | 04:05 PM
eddie jr's Avatar
Will it still log the information in the raw data even though you don't see it occur in the program? Or you just miss the info all together??
Do you have a link to the cable style you are speaking of?
Old Jun 23, 2004 | 06:21 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I believe this is the cable youll want to build.
Old Jun 23, 2004 | 06:31 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Each byte transmitted by the ALDL is a snapshot of whatever that memory address has stored in it at that immidiate time. If something is occuring at the same time the byte was origionally stored and later loaded for transmission, youll see it. If it occures between successive loadings youll miss it entirely.
Old Jun 24, 2004 | 09:32 AM
Captain C's Avatar
Car: 1985 IROC-Z
Here's a good place to look for stuff if you don't want to build it yourself....
http://www.moates.net/gmecm/hworder.html
Old Jul 5, 2004 | 07:56 PM
Matthewy8's Avatar
Car: 92 Firebird
Engine: 3.1 V6
is there a wiring diagram of the 8162 baud aldl connector needed for datalogging? i have the newer computer and i have yet to find a diagram of how to build this connector.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Pinguiclia
Oct 12, 2015 04:47 PM
Nervous2
Oct 8, 2015 10:53 PM
