Commander 950 Communication Cable
Old Jul 13, 2004 | 10:45 PM
muffz28's Avatar
Car: 1992 Camaro Z28
On the cummications cable for the C950 there are four holes but only three wires. Is this correct. I missing a wire for the number 4 pin which is for the A2 and A3 pins on the commander and I'm not communicating, ecu to laptop. Or is there another problem.
Old Jul 31, 2004 | 04:48 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I've got the same setup and the same problem...... anyone else out there???
I checked voltages at Pins (B1, C16 Battery) (A6 Ign/Switched power) and all have 11.5v I also checked grounds. The ECM itself is grounded well as are pins (D10 and B3)
Changed the fuse.
The fuel pump primes for about 4-5 seconds when the key is turned on like it's supposed to.
Com port works on my friend's 90 RS with WINALDL.
Old Aug 2, 2004 | 12:22 AM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Surprised Paul(twilightoptics) hasnt answered back yet, but I think he found out that the cable is pinned wrong.
Old Aug 2, 2004 | 10:43 AM
Yep, it looks like I may have a bad cable. 3 pins are how it should be.
To check use a volt/ohm meter to check continuity
"The way to check the cable is to take an ohmeter and make sure that 2 goes to 2, 3 goes to 3, 1(4 pin) goes to 5 (DB9). Pin 4 in the 4 pin is unpopulated. "
Old Aug 6, 2004 | 07:16 PM
muffz28's Avatar
Thanks guys. you've been a great help
Now I got other problems
Old Aug 6, 2004 | 08:20 PM
hehe welcome to my world! It was the cable. Made myself a new one with a DB9 connector and some wire!
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
ULTM8Z
Oct 2, 2015 01:25 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
