Knock sensor
Car: 87' GTA
Transmission: 700r4 soon to be a t-56 6-speed
Knock sensor
Hey guys, I was just curious if I could disable the knock sensor in my ECM without F@#king it up or my engin? Thanks, Ben
Car: check
Engine: check
Transmission: check
Re: Knock sensor
As for the engine, well, it all depends upon it's propensity to detonate. If high then the motor can easily be damaged.
RBob.
Car: check
Engine: check
Transmission: check
So it might not be that good of an idea for me to tamper with my knock sensor then huh?
Once an engine is built for all-out racing, gears drives, flat tappet cams, solid engine mounts, open headers . . . the ESC system may not operate too well. Then it can be worth removing it.
On my vehicles I have found it to be an asset.
RBob.
FormulasOnly
Sep 10, 2015 09:07 PM
