no data
Car: 1990 YJ
Engine: 406 TPI
Transmission: TH350
no data
Okay guys, Im new at this so bear with me. I have a 350 tuned port out of an 85 camaro in my jeep. Bought an aftermarket harness, ecm (1227730), and prom from Howell Engine Developments. Been running this setup for a little over a year now with no major problems, until now. I recently got a code 43 even though I am running a resistor (3.9k) instead of a knock sensor (block hugger headers are too tight). Now for the problem, I hooked up a Tech One at my local Chevy dealership and keep getting "No Data." This actually happened last year when I scanned it just to do it, but since it was running okay, I didn't do anything about it. Today I put in a new computer, same thing. Should I try a new chip? I have no idea what to do, any help would be greatly appreciated! Thanks in advance!
Car: check
Engine: check
Transmission: check
Hopefully you will be able to connect to this setup. By running the '730 ECM I'd bet that the code is a '90-'92 SD setup.
Try setting the scanner to that vehicle. This would be '90-'92 TBI 5.7l VIN 8 vehicle.
If that doesn't work contact Howell Engine Developments and ask them which vehicle VIN or maskID is required to connect to the ECM/chip they provided.
RBob.
RBob.
Car: 1990 YJ
Engine: 406 TPI
Transmission: TH350
I've been trying to connect to both a 90 and 91 camaro. It always starts off okay, Is SES light on.....yes, Is SES code 12 flashing ..... yes, Then I get no data.
Car: check
Engine: check
Transmission: check
RBob.
Car: An Ol Buick
Engine: Vsick
Re: no data
The one I got from them, was well, odd.
