ALDL missing something
Old Aug 25, 2004 | 09:25 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I tryed to use winaldl but when I was hooking it up to the aldl port I noticed that I was missing all but one prong(little metal things) on the bottom row so I have no "M" to attach the red wire to I tryed the only on on the bottom (witch is the one on the far Left) but it did not work I had shops hook up scanners with no problem so is their a special way to hook up the wires to my car or do I need a new ALDL
my: car 1986 camaro Iroc-Z transplanted 350TPI(originallyLB9)
Old Aug 26, 2004 | 02:20 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i believe you need terminal E.
look here, fourth post down, Trickster has the pin outs
for the ALDL
https://www.thirdgen.org/techbb2/sho...aldl+connector
Old Aug 26, 2004 | 07:32 PM
kairles's Avatar
Engine: 383/LGX
thanks I try that
Old Aug 28, 2004 | 02:55 AM
kairles's Avatar
Engine: 383/LGX
it worked thanx
Old Aug 29, 2004 | 05:15 AM
DENN_SHAH's Avatar
no problem
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
