What am I missing on these 150lb injectors?
Old Oct 19, 2004 | 03:05 AM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
150lb injectors at summitracing.com
Accel injectors for size comparison
They appear to be high impedence injectors (14.6 ohms).
The only thing I can see is that some of the dimensions are a bit different:
o-ring diameters are smaller, seat to seat heights are different (compared to accel injectors for example)
Does anybody use these? How can they be 150lb/hr?
Old Oct 19, 2004 | 08:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
It seems to be correct..
http://www.fordracingparts.com/parts...tKeyField=3765
Never heard of them before.........
/N.
Old Oct 19, 2004 | 12:57 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
Unless your running a twin turbo 706ci big block monster, I dont see why you need 150# injectors.
Old Oct 19, 2004 | 11:43 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Biggest saturaded injectors I've head of is #60's, larger is usually p/h-style..
/N.
Old Oct 20, 2004 | 09:11 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
/N.
There are 90s (saturated), but they are really expensive. PT+E is selling the 60s, as 65s since they seem to all flow to the high side of spec..
Old Oct 31, 2004 | 12:51 AM
Spifz's Avatar
What/where is PT+E?
Thanks.
Old Oct 31, 2004 | 11:10 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Precision Turbo & Engine. http://www.precisionturbo.net/
92projectcamaro
Jan 18, 2016 08:00 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
BAMiller
Sep 14, 2015 06:38 PM
