Dual ECM possible?
Old Oct 25, 2004 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Dual ECM possible?
I was thinking, it would be cool to have a dual ECM setup, with a toggle switch to toggle between two ecm's, one with a chip burned for track/racing and another for highway/fuel milage.
I would picture it as having all the wires spliced into two seperate ecm's and with the car turned off of coarse, can flip the switch to be running off one ecm or the other.
i can pick up a new one at work for 75 bucks and i might give it a try.
thoughts suggestions? is their already something out their that will do the same thing?
Old Oct 25, 2004 | 01:51 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Would it not be better to have two chips with different calibrations and select which one to use with a switch?
Or even better, use a bigger than stock chip and store many calibrations in it. Then use a remote switch to select what calibration to use?
It has already been done ... check this out:
http://www.moates.net
look at G3
Old Oct 25, 2004 | 08:54 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Dual ECM possible?
Some sensors can't be shared.
Other then for using race gas, one chip can do both.
As mentioned there are *chip* switches already available.
Old Oct 25, 2004 | 11:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
sweet didnt know that thanks!
Old Nov 16, 2004 | 02:32 AM
BrandenCali's Avatar
There was a Computer made that had a dual stage chip! You have to find the Article of these 2 3rdgens.. One is Yellow one is Red They called them Something like Tuned port injection but they used something else to stand out the power they were making..
I might have the issue somewhere still i will let you know any info I can find..
BrandenCali
88SS6SPEED
Nov 11, 2015 07:05 AM
customblackbird
Oct 1, 2015 04:30 PM
jer4251
Sep 27, 2015 09:52 PM
IROCNParts
Sep 24, 2015 10:50 AM
Eric-86sc
Sep 22, 2015 08:25 PM
