aldl connector
Old Oct 27, 2004 | 09:03 PM
High Toned SOB's Avatar
Car: 85 T/A
Engine: BBC
Transmission: glide w/brake
aldl connector
I am starting to wire up my first DIY injection system, and need some help. I have a new Hewlett Packard laptop, with the athlon processor which I will be using for my tuning. I also am going this weekend to a junkyard in zanesville that is littered with blazers,cav's and thirdgen/fourthgen cars. I am going to try and pickup about $300 worth of ECM's. I work at a GM dealership here in Cambridge, so I do have access to the TECI and TECII scan tools. ALso many new wire connectors and new pins and such.
1. I have the adapter cable for my laptop but it is for OBDII. Can I start gathering the OBDII connectors and rewire them (from what I;ve read, most of you use the Old style square connector), but since my adapter has the new I would like to use it?
2. I am going to gather up 1227730 and 1227749 ECM's, are there any others that will work that I could grab?
thanks
Old Oct 27, 2004 | 09:47 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Pick up 7727's if you see any. Look for 90-92 V6 cars like Beretta's and Regal's etc. It's the weatherproof version of the 7730, perfect for mounting in the engine bay.
You can use any kind of connector you want, as long as the wires all go where they need to.
Old Oct 30, 2004 | 01:29 PM
Car: 85 T/A
Engine: BBC
Ok, I got some puters. There are a TON of mid eighties to mid nineties buicks, lumina's, regals, cav's, blazers there. Ifound a list on this site and printed it off for computers to get, but alot of the cars that were listed did not have the same number as what the list said. Some were remans,some weren't.
Now the biggest thing I noticed was that some of them are two plug while others have the three plugs. What is the difference? I got a couple from 86 and 88 Camaro's w/v8, and those looked very similar to the ones that are in blazers. They are all 2 plug. The one from the cavalier (88z24) has three plugs, and the ones from the Lumina's have 3 plugs.
I did snag 1 black 4 plug from a 98-00 Vortech Suburban. I would like to use it on my S10 Blazer v8 conversion.
I didn't see any 7749's and 7727's. There were a lot of regals and other w/n body cars there, but they all have the 3 plug harness's. After seeing the one's that I pulled out of the Camaro's, they are totally different looking, so I stopped getting them. I couldve gotten probably 20 of them.
Does anyone have a list of ALL the computors that will work, I checked around at work and one of the OLDer mechanics said the 7730 was used alot, from F/S chevy trucks to cars. I did not see this on the list from this website however. Could anyone verify?
Old Oct 30, 2004 | 02:23 PM
Car: 85 T/A
Engine: BBC
Car: 85 T/A
Engine: BBC
Old Oct 30, 2004 | 04:12 PM
TheGreatJ's Avatar
The '7730 is the standard inside-mount speed-density computer. It was used on all kinds of stuff.....from the 2.0 Tempest to the L98 Camaro. The '7727 is it's weather-proof sister (for engine bay mounting.....you won't find it under any dashes.) The '7727 is black and has 4 square "weatherpack" connectors instead of the typical 2 or 3 long connectors.
The 3-plug Cavy ECM should be a '7730, and the 2-plug ones are '165 MAF ECMs most likely. If it's an aftermarket replacement it'll have a different part number, but it should still have the GM number on a label somewhere.
Old Nov 2, 2004 | 08:29 PM
Car: 85 T/A
Engine: BBC
16196397
is this usable??
mike
Old Nov 2, 2004 | 09:50 PM
TheGreatJ's Avatar
Anything is useable, it's just a question of what it can be used for. That said, I can't find that number in my cross-reference. What did it come out of? If it has a removable PROM it can be hacked and subsequently tuned and adapted. It's just a question of how much of the work has already been done.
Old Nov 3, 2004 | 08:11 AM
Car: 85 T/A
Engine: BBC
It came out of a 95 lumina car, yes it does have the removable chip.
Did you get the picture I sent you email? I couldn't post them on here, so I hope you got them.
Thanks,
Mike
it was underhood also, 3 plugs: white, blue, and grey/black
It is weatherproof, pretty thick aluminum housing
OK, I just grabbed one out of a 92 Regal w/3800 seriesII. It has the number
16132792
but says replacement. Is this the replacement for the 7727? It is black metal with 4 plugs and IS watertight?
Old Nov 4, 2004 | 08:01 PM
TheGreatJ's Avatar
The '2792 was only used on the 3.8 V6 as far as I know. I'm pretty sure it's a MAF computer. Either way, it's not interchangable with the '7727.
Are you sure that Lumina computer is a '6397? Or is it a '6387? The '6387 is the MAF computer used on the '94-95 3100 V6.
Old Nov 4, 2004 | 09:48 PM
Car: 85 T/A
Engine: BBC
trying
Old Nov 4, 2004 | 10:03 PM
Car: 85 T/A
Engine: BBC
stupid pictures won't work
Old Nov 5, 2004 | 06:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by High Toned SOB
trying
I think that you need to be a Senior Member before one can post pics. It doesn't take too many posts to get to the Senior level.
RBob.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
