383 dfi tables
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
383 dfi tables
was wondering if some can post their timing and fuel tables if any of u have a similar combo to mine.heres the combo.
383 stroker
9.5:1 compression
afr 195cc heads
acell lower intake
slp runners
ported stock plenum
58mm tb
30 lb injectors
comp cams lift(intake).503 (exhaust).510 duration (intake) 224 (exhaust)230.
thanks.
ps its acell dfi gen6
383 stroker
9.5:1 compression
afr 195cc heads
acell lower intake
slp runners
ported stock plenum
58mm tb
30 lb injectors
thanks.
LT1Formula
Oct 8, 2015 08:34 PM
efiguy
Sep 27, 2015 01:30 PM
